DaTr_4751301
5 questions asked 5 replies posted 5 sign-ins
I am not sure if this is the correct forum.  I was previously working on development using WICED studio and Laird-EWB.  I was informed recently that the WICED platform is NRFD.  I installed stm32cubeide and st tools to configure the stm32f412 mcu.  All is well.  I then downloaded the MODUSTOOLBOX and it appears to only support BLE apps.  Where can I go to get the api and libraries for the classic bluetooth interface.  I am primarily looking for RFCOMM and Dual Mode.
Thank you
BragadeeshV
Hi @DaTr_4751301 ,
Our BT host stack library supports BT classic. Check here
API reference manual -  https://infineon.github.io/btstack/dual_mode/api_reference_manual/html/index.html
API - https://github.com/Infineon/btstack
You can use the STM Connectivity package which is basically a sample porting to use BTSTACK on STM host. We have only support for BLE examples in this official release. However, you should be able to include the dual mode version of this stack and should be able to run BT  classic profiles on it.
https://github.com/Infineon/stm32-connectivity/tree/master/Middlewares/Third_Party
Also, please note that 4343W is NRND. We recommend you to consider using latest devices such as CYW4373, CYW43012, CYW43439 based on your feature requirement.
Bragadeesh
BragadeeshV
Hi @DaTr_4751301 ,
Bragadeesh
Hello BragadeeshV ,
Thank you very much for the info. This looks outstanding. Onward and upward.
Have a good day.
Dan Trautman
dan@dijitized.com
603-473-2144
