Hi i am trying to test EZ BLE modules and i have downloaded Mesh_Snip_Performance_Testing and Mesh_Snip_Provision_Client, following the procedure shown in https://www.infineon.com/dgdl/Infineon-PSoC_Programmer_Release_Notes_Version_3.28.7-Software-v01_00-...
However, when i access ClientControlMesh through ModusToolbox IDE, i cannot find any options that specify Models, Configuration and Mesh Performance tabs. I can only see Light Control tab available. I am pretty sure i am on an updated btsdk (ModusToolbox 2.4.0 linux). What is going on? How do i find the Mesh Performance tab for testing purpose? Thanks.
- AIROC™ Bluetooth
Could you please try to get the ClientControlMesh application from the below link and try?
https://github.com/Infineon/btsdk-host-peer-apps-mesh/tree/master/host/VS_ClientControl/Release
-Dheeraj.P.K
-Dheeraj.P.K
Hi, VS_ClientControl cant be opened in linux, it is a .exe file. the qt client control from the link you sent can be opened but it does not have the mesh performance tab as well
The mesh performance tab is not available in qt client control.
Please use the windows version.
