- Email to a Friend
Hi~
I want to build a sample application named 'Audio_Headset_and_speaker'
But I failed to build in CYBT-343026-01
I imported Audio_Headset_and_Speaker application and changed some code for adapting CYBT-343026-01 module, for example makefile and library files.
But I failed to build.
I'd like to know whether it can be built in CYBT-340326 succeedingly.
BRs
Daniel Lim
AIROC™ Bluetooth
- Email to a Friend
Hi @shlim
Audio_Headset_and_speaker application is under CYW20721. It may not be directly compatible with CYW20706.
Can you check the audio applications under CYW20706 EVAL in MTB for CYBT-343026-01
Anjana
- Email to a Friend
Hi @shlim
Anjana
