Hi~
I want to make a demo board with CYBT-3430260-01 EVAL board
I succeeded to import Audio headset application from CYW20706 BSP.
So, I can hear the music through CYBT-343026-01.
But I have faced the issue for the button function like as volume up&down and play&pause.
I found the button library in CYW20721 BSP.
I wonder If I can import those library included 'bt_hs_spk_lib' from CYW20721 to CYBT-343026-01
Many Thanks
BRs
Daniel Lim
AIROC™ Bluetooth
Hello @shlim
20706 & 20721 uses different base Firmware. So there will be incompatible APIs.
But I think button library for headset speaker should be portable. Can you try and let us know if you are facing any specific issues?
Please note CYBT-343026 module will be having less GPIO pins comparing to base chips like 20706 / 20721.
Anjana
Hello @shlim
Anjana
