Jul 26, 2021
09:23 AM
Jul 26, 2021
09:23 AM
After i called function wiced_rtos_init_thread() several times successfully, each next call of this function fails.
It Returns with error code 0x10.
I call the function from exactly the same part of code, where i called it before.
Should this be caused by exceeding maximum size of stack?
And if so, where can I increase stack size?
Labels
Wireless
09:52 PM
Jul 28, 2021
09:52 PM
Hi @Rosta ,
Return value of 0x10 means WICED_NO_MEMORY. Can you please check the memory usage using wiced_bt_get_buffer_usage() and check if you have already exhausted the allocated memory?
Bragadeesh
Bragadeesh
