Hello Infineon Support team.
We would like to evaluate I2C master using CYW920721B2EVK-02.
In the first place, there are No I2C reference sample code for "KitName:CYW920721M2EVK-02" in ModusToolBox version 2.4.0.
So, instead of it, we referred following.
- Kit Name: CYW920721M2EVK-03
- Template App: HAL I2C Master
However, no I2C signals are observed at SCL(J3:1),SDA(J3:2) on the board.
Please give me advice to observe I2C signals using CYW920721B2EVK-02.
Tayo
Hi @tayo :
Please try to modify I2C function based on the sample code from BSP supported CYW920721B2EVK-02, and you can use "Device Configurator" for setting I2C.
Detail about "Device Configurator", you can refer to ModusToolbox™ Device Configurator guide.
For I2C master function, you can refer to I2C API document.
Colin
Hi @tayo :
Colin
