I want the CYW920721B2EVK-02 on which the Audio Watch is programmed to work as HFP Audio Gateway.
I tried the following steps, but it doesn't work as expected.
1) Create the Audio Watch project from github (IDE is Eclipse IDE for ModusToolbox Version 2.2.0).
2) Define HFP_AG_INCLUDED (value is 1) in Project Properties -> C/C++ General -> Path and Symbols.
3) Build the project and program.
4) Launch ClientControl and open port.
5) Select AG tab, but can't click buttons (HF tab is enabled).
How can I make it work as AG?
Gotoda
Wireless
Can you try editing the value in the makefile itself ? You don't have to define any symbols in the GNU C config.
-Dheeraj.P.K
Have you disabled Hands-free Unit ? i.e. HFP_HF_INCLUDED ?= 0
Have you opened correct Baud rate in clientcontrol? Try 115200 or 3000000
-DheerajP.K
I defined symbols as shown below.
However, AG does not seem to be enabled, and HF still seems to be enabled.
Gotoda
-Dheeraj.P.K
I solved the problem by editing the makefile.
Thank you.
Gotoda
