We are using CYW920721 eval kits for our development. When we measure the tx power using Cybluetool, does not give max power according to the datasheet. How to make sure the power setting are correct and it is using right power table.
Which command are you using?
When you set the tx power, please use the power table setting and set the index to 0. Don't set the power in dbm.
We did used power table index, never set the tx power. This how we tested already, can you please tell us is there any other configuration that we need to set to check the tx power.
Are you testing the classic BT or BLE?
