Hello good afternoon I would like to know the driver for development kit CYW920719B2Q40EVB-01
ispn:38626:1:0
l1:314:1:0
Wireless
- cyw920719b2q40evb-01
Have you tried recovery procedure as follow?
1) Press and hold "Recovery"
2) Press and release "Reset"
3) Release "Recovery" after a sec
Also, please check Appendix D here- https://community.cypress.com/t5/Public-Archive/CYW920706WCDEVAL-Evaluation-Kit-Guide/td-p/249006?at...
Hi @Arturo96 ,
You can directly use CYW20719B2Q40EVB-02 eval board with ModusToolbox. There is no need for any drivers as such.
FVI https://community.cypress.com/t5/Resource-Library/CYW20719B2-Product-Guide/ta-p/251238
The problem is that I have the CYW920719B2Q40EVB-01 evaluation kit, and when I connected it to my computer through the USB port, the message that the device is not recognized appears, so I cannot configure it as PUART, so I asked if I could provide the driver
