Hi~
I should define a range of baud rate
Is there any baud rate limit for PUART of CYW920719 chip?
I already found some description for the limit of baud rate.
But I want to clarify the baud rate range of CYW920719B2.
Many Thanks
AIROC™Bluetooth
ispn:38626:1:0
l1:314:1:0
Hello @SeunghanLim
Please check the Baud rate details here: https://community.infineon.com/t5/Resource-Library/CYW20719-and-CYW20735-Peripheral-and-HCI-UARTs/ta...
Anjana
Hello @SeunghanLim
Anjana
Thank you for your reply.
Datasheet is same as the link above
I already tested it works with 9600bps
I want to know the loweset limit range of UART bps.
Because cusotmer should fix the manual if this chip doesn't support below 9600bps.
