CYW920719B2Q40EVB-01 PUART ISSUE
Nichol
Distributor - Future(GC)
5 replies posted 10 sign-ins 5 sign-ins
Use CYW920719B2Q40EVB-01 EVALUATION KIT by Modustoolbox,Application:HAL-PUART,cannot realize the result of this program.
Hardware connection are as follow:
Logic Analyzer CH0--J10 TX
                               CH1--J10 RX
                               CH2--D1
Software operation situation:
Send character 4 to the SoC three times,but no response.
Did I do something wrong?
ChiP_16
5 questions asked 5 likes given 5 solutions authored
Hi Nichol,
The application code sent out some text on reset. It is also not received on your COM program. I doubt you made any changes to device configuration. Anyway, I have attached the screenshot of mine for your reference.
Pong
ChiP_16
Hi Nichol,
It is not clear on your photo, is there a jumper between J10(5-6)(TX) and J10(7-8)(RX)?
Pong
Nichol
Hi,Pong,
the jumper both have been taken off.
ChiP_16
Hi Nichol,
You need jumpers between J10(pin 5 and pin6)(TX) and J10(pin7 and pin8)(RX).
Refer to schematic for details.
Pong
Nichol
This pin now connected. The same result.
ChiP_16
Hi Nichol,
There are 2 com ports for the board. Please use the WICED Peripheral UART port. I have also attached a photo of the board with the jumpers. I am able to run the HAL_UART application without issue.
Pong
Nichol
Hi Pong,
The Hardware and software config are as follows,should I set the Bluetooth address first?96e452702ccd297293d5510ef830cedb.jpg25071831a2a91cfdd8e17790556791e1.jpg
ChiP_16
Hi Nichol,
HAL_PUART does not involve Bluetooth, no need to set Bluetooth address. Your settings are similar to mine.
Did you program the board?
Pong
Nichol
Hi Pong,
The programming screenshot is as follows,thanks.
Nichol
ChiP_16
Hi Nichol,
Pong
