- Email to a Friend
we are evaluating some Infineon BT chipsets & modules.
We use external BT stack, so we interface w/ the chipset/module via HCI port.
- CYW920706WCDEVAL: no problem at all. We power the board w/ recovery button pressed and then release. Module enters in HCI mode and w/ cybluetool we are able to send/receive HCI commands/events. Inquiry results are reported correctly.
- CYBT-343026-EVAL: we do the same steps. HCI commands/events are sent/received, but radio seems to be off. We don't have any result for inquiry, as you can see (I tried also to enable radio by mean of vendor specific command).
07/04/22 14:09:06.388 com21@115200 c> Enable_Radio
HCI Command
com21@115200
[34 FC 01 ]: 01
opcode = 0xFC34 (64564, "Enable_Radio")
Enable_Radio = 0x1 (1)
07/04/22 14:09:06.399 com21 <c Enable_Radio
HCI Command Complete Event
com21@115200
[0E 04 ]: 01 34 FC 00
event = 0x0E (14,"Command Complete")
Num_HCI_Command_Packets = 0x1 (1)
Command_Opcode = 0xFC34 (64564, "Enable_Radio")
Status = 0x0 (0, "Success")
07/04/22 14:09:09.725 com21@115200 c> Inquiry
HCI Command
com21@115200
[01 04 05 ]: 33 8B 9E 08 00
opcode = 0x0401 (1025, "Inquiry")
LAP = 0x9E8B33 (10390323)
Inquiry_Length = 0x8 (8, N * 1.28 sec, 0=infinite)
Num_Responses = 0x0 (0, 0=unlimited)
07/04/22 14:09:09.731 com21 <e Command Status
HCI Event
com21@115200
[0F 04 ]: 00 01 01 04
event = 0x0F (15,"Command Status")
Command_Opcode = 0x401 (1025, "Inquiry")
07/04/22 14:09:19.972 com21 <e Inquiry Complete
HCI Event
com21@115200
[01 01 ]: 00
event = 0x01 (1,"Inquiry Complete")
Am I missing something? Why inquiry is not working on CYBT-343026-EVAL? The same topic was discussed here (https://community.infineon.com/t5/Studio-Bluetooth/hcd-file-for-BCM20706A2/m-p/118427) but no resolution was given.
Thank you for the support.
Alessandro
- Email to a Friend
Hi Dheeraj,
thanks for the feedback. I was already using Method2 described in the blog and it was not working.
I managed to let it work performing executing reset w/ button on the board (now via HCI).
So, the steps are:
1) create empty project w/ modustoolbox and change code as described in method 2 of the blog;
2) power off / power on
3) press reset button (this step is required from my tests)
4) HCI is ready
Thank you.
Alessandro
- Email to a Friend
Could you please send HCI_Reset at the starting and try the other commands you require?
please refer to below blog to know how you can get the general patches for the controller. You need these general patches for the chip in order to work it as expected with the latest spec/qualified features.
-Dheeraj.P.K
- Email to a Friend
Hi Dheeraj,
So, the steps are:
4) HCI is ready
Thank you.
Alessandro
