We have integrated CYW89820BWMLGT module with imx6ul processor and have flashed firmware.bin and minidriver.bin firmware to this chipset. We tried changing MAC address using bdaddr command [bdaddr -i hci0 00:01:E3:64:DD:9B] but, we were unsuccessful in doing the same. The output after we run the same command is as shown below:
Manufacturer: Cypress Semiconductor Corporation (305)
Device address: 20:81:9A:1F:4F:50
Unsupported manufacturer
We also tried changing the MAC address by using the hcitool command [hcitool cmd 0x3f 0x001 0x01 0x23 0x45 0x67 0x89 0xab] but, we were not able to do the same either. The output after we run the same command is as shown below:
HCI Command: ogf 0x3f, ocf 0x0001, plen 6
AB 89 67 45 23 01
> HCI Event: 0x0e plen 4
01 01 FC 00
Please look into the same and kindly guide us on if there are any other commands that needs to be executed for changing the bluetooth MAC address.
Akshay Naik
Hi Akshay,
Please check hcitool command here- How to change Bluetooth MAC address on Raspberry Pi 4
Can't Set Bluetooth MAC Address
Since CYW89820 is not a broad market chip, there is a limitation on supporting it in Community. So for more details and documentations, I would suggest you to contact the Cypress Sales - https://www.cypress.com/about-us/sales-offices
CYW89820 product guide: https://community.cypress.com/t5/Resource-Library/CYW89820-Product-Guide/ta-p/259242
Hi Akshay,
