CYW4343W BLE PER Test
KOK_4840576
First solution authored 10 questions asked 5 replies posted
Good Day!
We are using CYW4343W in our design (Murata 1MW). We would require to measure bit error rate (BER). The module UART is connected to the PC.
1. Do we need to use specific test firmware  for Bluetooth testing( different from mfgtest firmware used for Wi-Fi) ?   If yes where do we get the firmware?
2. Can we use the CyBluetool  for sending HCI command to the module from the PC? What are the other options?
3. How to download the test firmware on to the CYW4343W module?
4. Can you list the specific HCI command sequence  to measure Packet Error Rate and details to interpret the result?
Thanks!.
Tushar_b
100 replies posted First like given 25 solutions authored
All you need to do is to enable test mode the same way you setup the DUT for BQB tests.
The BT tester like CBT or CMW should run the BER test while you inject the blocking signal.
See attached CyBluetool User Guide on how to enable test mode in section 1.7.
Tushar_b
We are working on your query and will update you soon.
Tushar
Thanks.  Could you also let us know how the test flow in the below scenario as well.
5. CYW4343W interfaced with i.mx host through UART and we want to test through CMW500 tester?  How to use the DTM (direct test mode) in this case.  How DTM test for Bluetooth is typically done in hosted modules?
Tushar_b
