Hi there,
I'm trying use a external microphone with my CYW208xx (CYW920819EVB-02) . The output of the mic is a PDM signal. Now I set the GPIO to PDM_IN 0 and connected the data line from the mic. My question now is:
Is there any documentation on how to use the PDM interface with Modus Toolbox? I would like to know the following things.
- What functions do I use to start the "recording" ?
- How do I change the sampling rate ?
- How can I output the filtered samples ?
"The CYW208xx accepts a ΣΔ-based one-bit pulse density modulation (PDM) input stream and outputs filtered samples at either 8 kHz or 16 kHz sampling rates."
(I found the wiced_bt_audio_record.c and pdm_aud_record.c but both include wiced_bt_audio_record.h which i can not find. )
thank you in advance !
ispn:38628:1:0
l1:314:1:0
Hi @HTerm1
Our Bluetooth chips supports only I2S / PCM interface to use A2DP/HFP profiles for audio streaming.
Anjana
Hello @HTerm1
We do not have PDM library support for 208xx devices.
Please refer to the Technical brief doc for supported & unsupported features & example codes.
Anjana
Thank you for your reply !
I'm trying to implement a Bluetooth microphone. I'd like to use a external digital microphone (output PDM) combine it with a MCU+ Bluetooth chip and send/stream the recording to a smartphone, so I can listen to the recorded sound.
Which chip would you recommend for such a audio application?
Thank you in advance, BR
Hi @HTerm1
Anjana
