On our SPP firmware that supports single connection, we are facing the problem that when multiple device try to make connections at the same time, both ACL links are established.
We want to limit the number of acceptable ACL link to one or to disconnect the 2nd ACL link.
Does Infineon offer the APIs to be able to use for this aim?
*We have tried to disable the page scan (HCI Write_Scan_Enable) after 1st connection has been established, however it is not work as we expected.
In my opinion, the application should handle the number of peer devices supposed to be connected to our device. Once the required number of peer devices is connected, we can set the discoverability and connectability appropriately and limit the future connections.
wiced_bt_dev_set_discoverability
wiced_bt_dev_set_connectability
-Dheeraj.P.K
