On our SPP firmware that supports single connection, we are facing the problem that when multiple device try to make connections at the same time, both ACL links are established.
We want to limit the number of acceptable ACL link to one or to disconnect the 2nd ACL link.
Does Infineon offer the APIs to be able to use for this aim?
*We have tried to disable the page scan (HCI Write_Scan_Enable) after 1st connection has been established, however it is not work as we expected.
AIROC™ Bluetooth
In my opinion, the application should handle the number of peer devices supposed to be connected to our device. Once the required number of peer devices is connected, we can set the discoverability and connectability appropriately and limit the future connections.
wiced_bt_dev_set_discoverability
wiced_bt_dev_set_connectability
-Dheeraj.P.K
Hello @ToKo_4602001
From your description I believe your device should not allow a second SPP connection when the first one is active. Is that correct?
Can you please try to modify the below config parameter under wiced_bt_cfg_settings_t to 1 and try?
.rfcomm_cfg = /* RFCOMM configuration */
.max_links = 1, /**< Maximum number of simultaneous connected remote devices. Should be less than or equal to l2cap_application_max_links */
.max_ports = 1, /**< Maximum number of simultaneous RFCOMM ports */
Anjana
Thank you for quick reply.
==> Yes it is. My device should not allow a second SPP connection.
==> I have tried this to limit the number of SPP connections. But a lower 2nd ACL connection is accepted...
So we have faced internal error.
-Dheeraj.P.K
