I am using CYW20706 as BLE peripheral,
and using nRF connect App to connect 4 mobile phones as central,
connect interval: 200ms, slave latency: 0, timeout 4800ms.
There did not do anything but only keep under connection.
Few hour later, there will happen disconnect and get the reason 0x08 supervision timeout.
After 2 devices disconnect with 0x08 and ohters 2 device still under connection.
I have read this https://community.infineon.com/t5/Studio-Bluetooth/Maximizing-number-of-connections-with-CYW20706/m-...
He seems to can stable connect 4 devices.
Is there any suggestion?
Hi @adam ,
Are you using any existing example project or any custom application?
Can you try with different connection intervals and see if it works?
Thanks and regards,
Advait Kulkarni
Hi @adam ,
Thanks and regards,
Advait Kulkarni
Hi @advait_kulkarni ,
I modify project base on hello_sensor,
I have tried connection interval 200ms,
but it still happen 0x08 supervision timeout.
Now I am testing connection interval 200ms and sleave latency 2,
It seems connect more stable than before.
