I am curious about what is the correct max Tx Power for CYW20706,
from specification it said +12dbm
, but according to URL, it said max Tx Power is +8dbm https://community.infineon.com/t5/Resource-Library/Configuring-Transmit-Tx-power-on-the-CYW20706/ta-...
if I configure .max_pwr_db_val = 9 and wiced_bt_ble_set_adv_tx_power multiple of 4 from +8 dBm to -16 dBm, it seems work.
The below picture is my roughly test.
Is it possible to configure tx power to +12dbm?
And how to configure .max_pwr_db_val ?
You can refer to the spec for the actual max/min/typical power values. The integer value input to the API as an argument is an indicative value only. It is not the actual power.
max_pwr_db_val can be configured in the wiced_bt_cfg.c/h file. Allowed range is 0 to 10dBm.
May I know how you are measuring the tx power? If it is RSSI, the power depends upon various factors of the receiving device, antenna, etc.
-Dheeraj.P.K
-Dheeraj.P.K
Hi @DheerajPK_41,
If I config max_pwr_db_val as 10 and call wiced_bt_ble_set_adv_tx_power (10), Tx power will be the maximum of CYW20706, is it right?
I use spectrum to measure Tx power of CYW20706, and find the biggest peak.
when I call wiced_bt_ble_set_adv_tx_power(10), the value is 8.425dbm.
