refer to before question: https://community.infineon.com/t5/AIROC-Bluetooth/CYW20706-wiced-sleep-config-bt-wake-host-wake/m-p/... .
I want to make sure usage about these two pins Dev_wake and Host_Wake .
If I do not run into power saving mode, can I config these two pins without any issue?
Especially, I want to pull Dev_wake and Host_Wake high during power on sequence,
will these procedure be alright?
Because of before issrue, we are very careful about these.
Adam
Hi @adam ,
The default state of these pins is active-low, however if you are getting them to high level on power on sequence, do assign the polarity accordingly in wiced_sleep_config_t and it should be fine.
Thanks and regards,
Advait Kulkarni
Hi @adam ,
Thanks and regards,
Advait Kulkarni
