I was wondering if it is possible to upgrade firmware or do you provide firmware images for Linux kernel for BLE device CYW20704 ?
I'm using Lair BT851 devices on my project and i noticed on few equipments (Raspeberry OS) that de usb BLE device hangs sometime .
Below are usb information of my device .
N: bus/usb/001/012
E: BUSNUM=001
E: DEVNAME=/dev/bus/usb/001/012
E: DEVNUM=012
E: DEVPATH=/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.2
E: DEVTYPE=usb_device
E: DRIVER=usb
E: ID_BUS=usb
E: ID_MODEL=CYW20704A2
E: ID_MODEL_ENC=CYW20704A2
E: ID_MODEL_ID=f901
E: ID_REVISION=0112
E: ID_SERIAL=Cypress_Semi_CYW20704A2_0016A4589279
E: ID_SERIAL_SHORT=0016A4589279
E: ID_USB_INTERFACES=:e00101:ffffff:fe0101:
E: ID_VENDOR=Cypress_Semi
E: ID_VENDOR_ENC=Cypress\x20Semi
E: ID_VENDOR_FROM_DATABASE=Cypress Semiconductor Corp.
E: ID_VENDOR_ID=04b4
E: MAJOR=189
E: MINOR=11
E: PRODUCT=4b4/f901/112
E: SUBSYSTEM=usb
E: TYPE=224/1/1
E: USEC_INITIALIZED=273085505650
Please create a SFDC case for this (20704 hcd) request. (Login to https://www.infineon.com/ and go to MyCases).
Also, you can contact our sales/FAE teams.
-Dheeraj.P.K
Hi rack_99 ,
Linux system usually load .fw or .bin file as firmware . If i'm correct .hcd file is for Android system.
I'm seeking a way ,if it exist, to upgrade the firmware of this chip.
-Dheeraj.P.K
