We try to install "RFCOMM_Serial_Port_1 Program" in the CYBT353027EVAL board but get following error. I have also tied to do the recover/reset procedure without any success, however I don't know in which step I have to do the rest, but I have tried a few different ways.
I wonder if you have any suggestions to do this?
COMMAND:
ERROR:
Programming target device ...
Detecting serial port ...
Serial port not detected...
Download failed
If the serial port was not detected, make sure no other program such as ClientControl has the port open.
If you have issues downloading to the kit, follow the steps below:
Press and hold the 'Recover' button on the kit.
Press and hold the 'Reset' button on the kit.
Release the 'Reset' button.
After one second, release the 'Recover' button.
make[1]: *** [../mtb_shared/wiced_btsdk/dev-kit/baselib/20706A2/release-v4.0.0/COMPONENT_20706A2/make/recipe/program.mk:102: qprogram] Error 1
make: *** [../mtb_shared/core-make/release-v1.9.1/make/core/main.mk:434: secondstage_build] Error 2
Artin
Please check the log below. You can see from the log that the device already receives the data from my phone.
You can catch the app log first. If need further debug, you can catch the btspy log.
—…APP Start, interupt=1, timeout=0, loopback=0
app_management_callback 21
app_management_callback 20
app_management_callback 0
hci_control_write_eir 22a798
EIR :09 09 73 70 70 20 74 65 73 74 03 03 01 11 00
app_management_callback 9
app_management_callback 8
BTM_PAIRING_IO_CAPABILITIES_REQUEST_EVT bda ac d6 18 56 1e 45
app_management_callback 4
Pairing with: BdAddr:ac d6 18 56 1e 45 Status:0 Len:248 Name:Owen
app_management_callback 11
Pairing Complete: 0
app_management_callback 18
NVRAM ID:1 written :138 bytes result:0
app_management_callback 12
Encryption Status Event: bd (ac d6 18 56 1e 45 ) res 0
spp_connection_up_callback handle:2 address:ac d6 18 56 1e 45
spp_rx_data_callback handle:2 len:3 63-65, total rx 3
Power mgmt status event: bd (ac d6 18 56 1e 45 ) status:2 hci_status:0
Power mgmt status event: bd (ac d6 18 56 1e 45 ) status:0 hci_status:0
spp_rx_data_callback handle:2 len:6 63-56, total rx 9
spp_rx_data_callback handle:2 len:3 12-56, total rx 12
The recovery procedure is a little different for CYBT-353027.
Please refer to the following blog about how to do the recovery:
Thanks Owen!
I'll test it and let you know the result.
Hello Owen,
I managed to install RFCOMM_Serial_Port_1 Program in the module using your tip, but some communication still doesn't seem to work. The only difference is that I get "Allow access to your contacts and call history" when I pair the module with an Android tablet. I have two questions:
1. Is installing RFCOMM_Serial_Port_1 enough to use the module to send and receive data via serial port?
2. How can I verify my installation by reading what is installed in the module?
Artin
To test the SPP function with the module, you will need an apps on your phone which can support the SPP profile.
Owen,
Yes, I'm aware of it clearly. Our product (the hardware) works properly with our application for Windows and Android with another BT module. My intention is to replace the old BT 2.1 with a newer module and because CYBT-353027-02 seems be a good choice at leas according to the data sheet, I decided to give it a chance.
Please let me know if you can answer my previous questions.
Artin
Thanks Owen! I saw that you have redirected the signals to PUART and stopped the Btspy test on three lines. But it didn't help us. Our exiting BT on the hardware side acts as client and the application acts as master to stablish the connection. Maybe there is something there we need to change in the code. Have you any suggestion?
/Artin
Could you connect the module with your android device?
Can it send data to the module? Please share some logs as I can't see the problem on my side.
No, you just can pair them. No signals on UART at all.
Would you please explain which kind of log you need? Then I'll make them exactly as you require and send you.
Pairing Complete: 0
