I'd like to change BT module to communicat with HCI Uart instead of PUART
So. I succeded to change mode by using sample application 'Firmware_Upgrade_via_HCI' in modus tool.
But My customer has only module not EVK board
1. I need HCI uart mode patch ram for CYBT343026-01
2. I need How to download firmware in case of that customer only has a module only?
3. Do I have to need debugging tool, or download tool?
4. If there is no firmware in module. How can I support in that situation?
Thank You for your support
Many Thanks
Wireless
Please check the readme of the HCI firmware upgrade application for the instruction. This instruction tells how to build the application and use client control to upgrade the firmware. Client Control is a host MCU app/tool which demonstrate the use of WICED HCI protocol to control embedded apps. Its source code is also available.
https://github.com/Infineon/btsdk-host-apps-bt-ble/tree/master/client_control
Please refer below documents for more understanding.
https://github.com/Infineon/btsdk-docs/blob/master/docs/BT-SDK/WICED-HCI-Firmware-Download.pdf
-Dheeraj
-Dheeraj
