I'm looking for a clear input on the allowed TX Power for the CYBT-483056-02 module. I've read these topics :
but still I haven't been able to clearly figure out what are the maximum allowed Tx power.
Can you please fill the table bellow so that we know if we can use this module :
Regulatory \ BT Mode | BLE | BT EDR |
FCC | ||
CE | ||
MIC |
Regards, Jerome
The maximum TX power is 20dbm per the datasheet.
Hi
No the datasheet says 20dBm for the fcc, and 10dbm for the CE, but this is not clear if these figures are for the BLE or/and BT classic.
See the attached picture, i've overlight the datasheet certifications.
Also, Can you please complete the table that I attached...this would be more clear for everyone, because the datasheet gives some numbers, certification results give other numbers, you answer with one number for all...
Also I didn't accept your answer as a solution, why was it automatically accepted ?
Regards Jerome
I just checked the report internally. Please find the table below:
Thank you.
