I'm trying to flash a hex file (from modustoolbox) to a prototype which uses a CYW20721 module (CYBT-423060-02).
For this purpose, I will use a FTDI to program the module using UART.
I saw this article : https://community.infineon.com/t5/Knowledge-Base-Articles/WICED-Module-Programmer-User-Guide-KBA2250... that explains how to do this for older modules. Since the article is from 2018, the provided software "WICED Programmer guide" doesn't support CYW20721 based modules.
So, my question is: does someone know where to find an up to date version of this software (or the name of the software that replaced it) ?
Théo
Please use the attached tool and program by selecting CYBT-413061-02 device.
I need some time to check it with the app developer.
Thank you very much for your help, it seems to be what I was looking for.
Théo
