clive_buxton
First question asked First like given Welcome!
Hi, we're trying to get started with the  CYBT-353027  module and EVAL board,  (or any small audio and BLE capable module will do instead)
Having lots of problems with the whole environment, all the docs point to wiced ide which seems to be no longer supported.
What's the best plan?
AnjanaM_61
First comment on KBA 5 questions asked First question asked
CYBT-353027 is supported on MTB IDE which is latest. Unfortunately the module getting started appnotes are still on WICED SDK. https://www.infineon.com/dgdl/Infineon-AN223400_Getting_Started_with_EZ-BT_WICED_Modules-Application....
However the code flow and basic explanation remains valid. We are working with module team for updated Appnotes.
For getting started with MTB , I would suggest you to go through our Academy files here: https://github.com/Infineon/CypressAcademy_BT101_Files
Anjana
AnjanaM_61
Anjana
