- Email to a Friend
Hi Communities,
Our customer is planning to use the BT module as follows.
https://www.mouser.jp/new/cypress-semiconductor/cypress-cybt-343151-02-module/
They want to know the recommended current supply capability when using the module at 3.3V.
Could you tell me where I can find the answer for that?
T. Shibutani
AIROC™ Bluetooth
- CYBT-343151-02
- Email to a Friend
There isn't a recommended current capability. You can refer to table 13 in the datasheet about the peak current for the TX and RX.
BTW, we use a 240mA LDO regulator in the CYW20706 Eval board which you may be a reference.
- Email to a Friend
