I am trying to send audio data with I2S sink example in CYBT-343026.
And I am using MAX98357A as an audio codec.
I couldn't get the sound from the speaker after connecting the two evaluation boards.
I found out that the Data signal from CYBT-343026 has a low voltage lever which is 1.13V.
(Please find the attached oscilloscope capture below)
since the audio codec needs min 1.3V for input audio data.
I need to know what I should change to get enough voltage levels.
(other two BCLK, WS has enough voltage lever of 3V)
AIROC™ Bluetooth
- a2dp sink
- cybt-343026
Could you please try using Modustoolbox & BTSDK since it is the latest software. It has CYW20706 support. The bug fixes will be released in the latest software only.
-Dheeraj.P.K
Are you using the CYW920706WCDEVAL or a custom kit? Also, may I know which application are you using?
Let us check it at our side and get back to you.
-Dheeraj.P.K
I am using CYBT-343026-EVAL board.
And for the application, WICED-Studio, 20706-A2_Bluetooth, snip.bt.a2dp_sink
-Dheeraj.P.K
Hi Dheeraj,
I've already tried to use ModusToolbox at first.
But it doesn't support CYBT-343026-EVAL. That's why I was trying with Wiced Studio..
You can find the supported_targets in the down below. I will also attach the capture of the code.
Update
The app supports CYW920706WCDEVAL. We can port the app to CYBT-343026-EVAL and use it. CYBT-343026-EVAL also has the same chip (CYW20706). The difference is between the BSP - Hardware configurations.
