AIROC™ Bluetooth Forum Discussions
Da_Vinci
25 sign-ins 10 sign-ins 5 replies posted
I am using CYBT-343026-01, using Bluetooth Classic is it possible to serve HTML pages over HTTP server using any profile?
Here once I connect to Cypress Bluetooth module and typing IP_address:port_number in web browser on phone or PC I should see the webpage.
DheerajPK_41
Update:
This configuration cannot form an exact Bluetooth tethering network. Here if communication between SoC and CYBT-343026-01 is PUART whihc will completely lower the data rate and I am not sure how to share the HTTP request and responses encapsulated over PUART. For the tethering network, I guess we have to implement  Bluetooth Network Encapsulation Protocol (BNEP). Please check https://www.bluetooth.com/specifications/specs/personal-area-networking-profile-1-0/. Android has the package BluetoothPan I guess.
DheerajPK_41
I didn't get your query clearly.
Do you want to build something similar to Bluetooth Tethering (PAM) device?
-Dheeraj.P.K
Hello Dheeraj,
I am new to Bluetooth Classic so I am not sure what PAM device is, There will be a server running on SoC. To this SoC CYBT-343026-01 is interfaced over PUART. When I connect to this module by phone or PC > go to the browser > type IP address and port number I should see a webpage!
Will Bluetooth Tethering achieve this requirement?
DheerajPK_41
Update:
