I am trying to configure the CYBT-343026-01 BLE module for CYSPP mode. I am experiencing what I believe is unexpected behaviour in peripheral mode.
My setup is:
CYBT-343026-01, CYSPP (pin 22) => GND, LP_MODE (pin 4) => VDD.
On initial bootup, the module behaves as expected - passing all data transmitted to characteristic handle 0x11 to my serial terminal (see below)
Once I disconnect this terminal, the module re-enters API mode (see below)
This is happening even though I believe have disabled API mode in hardware by grounding the CYSPP pin. If I reconnect to the module, all data is now transmitted through the API mode UART interface (all data now encapsulated with "@E,...,D=data etc) which I would ideally like to avoid.
Would anyone please be able to let me know what is incorrect with my setup or thinking?
Any help would be greatly appreciated. Thank-you.
Wireless
Please try to use the latest FW which should be 1.2.29 and see if the problem still happens.
