Mar 07, 2021
06:30 PM
Mar 07, 2021
06:30 PM
Dear Cypress.
Our customer want to bridge 3ch Analog audio through CYBT-343026-01.
CYBT-343026-01 ADC connect to 3ch Analog audio, is this possible?
I think CYBT-343026-01 ADC pin 2ch support, is this right?
1ch : BT Audio.
2ch: USB/SD Card
3ch: Voice.
And Is This Streaming operate at the same time Possible?
Thank you.
Labels
- cybt-343026-01
10:39 PM
Mar 07, 2021
10:39 PM
Hi
just to clarify, you are looking to read 3 Analog inputs on the CYBT343026 and stream mixed output over BT as a A2DP source ?
Also if you want to use the CYBT343026 as an A2DP source the only compatible Inputs are I2S & PCM. The ADC input cannot be routed to Bluetooth as an A2DP stream.
Any more information would be helpful.
Winston
Winston
