Hi,Communites, I have a question about Company-ID part of Bluetooth Device Address
According to the KBA211407 as below,
https://community.infineon.com/t5/Knowledge-Base-Articles/Setting-Bluetooth-Device-Address-KBA211407...
my customer got their Company-ID form the Bluetooth SIG, but that has only 2-byte(16-bit) value.
I think Company-ID should be 3-byte(24-bit) value.
Is it OK that they add "00" to the upper side of the value?
Tadamasa Shibutani
Hello @NXTY_Shibutani ,
As per our knowledge company_id field can be added with the company identifier(2bytes with 00 prepend). For confirmation, we would recommend to check with Bluetooth SIG support team.
P Yugandhar.
Hello @NXTY_Shibutani,
Q1) Is it OK that they add "00" to the upper side of the value?
Ans: Yes, you can prepend 00.
P Yugandhar.
Hello, Yugandhar-san,
Thank you for your answer.
But I have another question.
My customer believes they can get Company-ID part of Bluetooth Device Address only from IEEE.
But according to KBA211407, it is written that can be got either from Bluetooth SIG or IEEE.
I found a similar Q&A as below.
https://community.infineon.com/t5/PSoC-6/Company-OUI-and-Company-ID-from-the-Bluetooth-SIG/td-p/3222...
I think it says that Company-ID part of Bluetooth Device Address is got only from IEEE.
Is it right?
Tadamasa Shibutani
P Yugandhar.
