- Email to a Friend
I currently working with CYBLE-213043 ,Can I use KITPROG3 programmer/debugger to flash externally the module. Could you please let me know what are the requirements for that.
regards
Surya Sundar
- Email to a Friend
Hi @SURYASUNDAR ,
Kitprog3 is an on board programmer/ debugger that is typically to used to program Infineon's microcontrollers in the evaluation boards. We do not recommend using Kitprog devices as standalone programmers/ debuggers. They may or may not be compatible and we do not guarantee its operation when used on other target devices.
We highly recommend you to purchase separate USB-UART bridges for programming the AIROC Standalone BT chips.
However, just for testing purpose you can try using kitprog as a USB-UART bridge for programming using HCI UART lines. This should not be used for main scale or production purposes.
Bragadeesh
- Email to a Friend
Hi @SURYASUNDAR ,
Bragadeesh
- Email to a Friend
Can you suggest to me which USB-UART bridges for programming the AIROC
Standalone BT chips.And what are the requirements need for that
- Email to a Friend
Hi @SURYASUNDAR ,
We do not have any recommended USB-UART bridge. Any USB-UART bridge should work. You may just have to ensure that they operate in the same voltage level.
Bragadeesh
