CYBLE-014008-00: recommended H/W design
NXTY_Nagata
Distributor - NEXTY (Japan)
5 solutions authored First solution authored 100 sign-ins
Dear supporters,
I am designing an IOT product using CYBLE-014008-00.
I have some questions.
1.BEL module placement
Is the A-2 configuration preferable to A-1 when placing a BLEmodule down below?
Or,Are the characteristics of radio wave the same for both A-1 and A-2?
2.Effect on capsensing
If a sensors for capsense are placed near the antenna on the BLE module, will capsensing be affected by BLE radio waves?
Is it better to place sensors as far apart as B-2?
If B-1 and B-2 are not recommended , could you give me some advice about recommended sensor placement?
Nagata
Yugandhar
Hello @NXTY_Nagata ,
1. Is the A-2 configuration preferable to A-1 when placing a BLEmodule down below?
Ans: A2 is better for antenna placement.
2. If a sensors for capsense are placed near the antenna on the BLE module, will capsensing be affected by BLE radio waves?
Ans: It is unlikely that RF will impact capsense, but the capsense can impact the antenna tuning and radiation pattern.
3. If B-1 and B-2 are not recommended, could you give me some advice about recommended sensor placement?
Ans: For sensors, B2 is better.
P Yugandhar.
Yugandhar
P Yugandhar.
