Hi~
When I tried to debug sample application(BLE_Eddystone), I found an error below.
Debugger exited unexpectedly during run. Encountered error (Target disconnected See output window for more information.)
I want to debug this devcie without error
BRs
AIROC™ Bluetooth
In Design Wide Resources ->System, please select the Debug Select to SWD as shown in attached image.
P Yugandhar.
Thank you for your prompt reply
But unfortunately I didn't solve the problem
I compared the source first and merged some differences. But debugging failed.
So, I used full integration by importing attached source file. But still failed.
I attached eddystone source file only.
please check it again
BRs
Any progress ?
It works very well
Thank you for your support
