hello, I am trying to CE212742 using CY8C6347BZI-BLD53 now.
Has anyone tried it?
if Link layer privacy (=LLP) is enable , then I don't find advertising signal,else find it.
but If you succeed and press the push button to confirm,Advertising signal don't find .
what't wrong?
Hi @hiroki
We are able to reproduce this issue at our end and we are working on finding the root cause for this issue for now can you try working with the PDL version 3.1.3.
Thank you for informing this issue.
Best Regards
Pratiksha V
Hi @hiroki
Please use the latest versions of the Psoc creator and PDL and also right click on the project and click on "Update components" option to update to latest version. I am not able to reproduce this issue at my end I have also attached my project please check it.
Thanks & Regards
Pratiksha V
Thanks to reply.
Maybe The version is latest.
but I don't find advertising.
so my envrioment's
pdl 3.1.5
psoc creator 4.4
Hi @hiroki
Are you facing this issue with the project which I had shared before?. Are you able to see the Red led blinking on kit which indicates the device is advertising?. Please can you share the screenshots of UART terminal logs.
Thanks & Regards
Pratiksha V
Hello @PratikshaV
→yes
thanks
Hiroki
Hi @hiroki
Please can you share us your example so that we can check at our end.
Thanks & Regards
Pratiksha V
Hello.
1,power on
2,please show advetising using windows pc and android(pixel5).
2.1,PC is found.1st capture.
2.2 Android is not found.2nd
Is it ok?
thanks
hiroki
Hi @hiroki
Best Regards
Pratiksha V
Hi @PratikshaV
After downgrading, it started working.
It was helpful. Thank you.
Kind regards,
hiroki
HI @PratikshaV
Would you reccommend to stick with PDL3.1.3 for the time being? Is there any implication you would expect for using 3.1.3?
Best,
TW
