Nov 22, 2021
01:05 AM
Nov 22, 2021
01:05 AM
I have with me the CYBT-343026-EVAL board. I have created LE_Hello_Sensor project using Project Creator.
- Can anyone please point me to a resource which explains the flow of hello_sensor.c
- Why there is no void main() function? Instead it has been replaced by APPLICATION_START().
Labels
ispn:40226:1:0
l1:314:1:0
04:10 AM
Nov 22, 2021
04:10 AM
Hello @Da_Vinci
There will be a readme file in the project folder itself which explains overview and steps to test the project. There is no other docs which explains the flow .
I think you are new to our BT chips & IDE. I would suggest you to go through our Cypress Academy files which explains the IDE , API usages and different blocks. Please have a look at : https://github.com/Infineon/CypressAcademy_BT101_Files
Anjana
