We have a product that uses the CYBT-343026-01 module. We need to carry out EMC testing of this product. We understand that there is some sort of Bluetooth/BLE test mode that forces the module into a continuous transmit mode that is intended for this type of scenario. In very simple terms can someone please explain the steps needed to activate this test mode.
Does the test mode have to be activated by the product itself or is this something that can be done remotely via something like a test App on a mobile phone?
Please accept the lack of knowledge here. The Bluetooth part of the product was created some time ago and the developers are no longer available to support so we are picking up the pieces here and trying to feel our way into this testing requirement.
One Bluetooth device should complete the SIG qualification and RF regulatory qualification before we release to the market. Please check the datasheet for such information on the CYBT-343026-01 module.
For RF testing, please refer below documents.
https://community.infineon.com/t5/Public-Archive/HCI-Based-Bluetooth-Testing/td-p/250835
https://github.com/Infineon/btsdk-docs/blob/master/docs/BT-SDK/Manufacturing-Bluetooth-Test-Tool.pdf
We can use cybluetool or wmbt tool to interact with the controller using HCI commands and events.
-Dheeraj.P.K
-Dheeraj.P.K
Many thanks for the links to the documents. These will be most helpful.
Mike.
