Jan 21, 2022
01:18 AM
Jan 21, 2022
01:18 AM
Hi, everyone,
I would like to carry out a RSSI measurement on both the central and the peripheral side for each individual channel.
Is it possible to enable only a single channel using the Cy_BLE_SetHostChannelClassification(...) function? The Bluetooth specification says that at least two channels must be enabled.
Is there a way to read the current channel?
In which c-file is the hopping algorithm programmed?
Many thanks for your help!
Labels
PSoC 6 MCU
- Channelmapping
- rssi
08:39 PM
Feb 06, 2022
08:39 PM
We have to set the required two channels with Cy_BLE_SetHostChannelClassification api.
You can use the Cy_BLE_GetChannelMap() API for reading current channel map only.
P Yugandhar.
