carlosfinocchia
5 sign-ins First reply posted First like given
I am working with a CYBT-483056-EVAL board and trying to connect to a Bluetooth classic device.  I am using a serial terminal to send commands to the eval board via the USB port.  I am unable to connect to a device. I tried connecting the first time (To pair) and the second time (To connect) and I'm not successful. I get error 500 and then error 1600. I don't know what those mean or how to fix it.
##### FACTORY DEFAULT (I want to start clean)
/RFAC
@R,000B,/RFAC,0000
@E,0005,RFAC
@E,0040,BOOT,E=01000A1B,S=02072276,P=0100,H=E8,C=00,A=EE596D3A570C,T=01
@E,000E,ASC,S=03,R=01
##### QUERY BONDS (No bonds at this time)
/QB
@R,000E,/QB,0000,C=00
##### CONNECT USING SPP (Error 500 is "GAP error category" What does that means?)
/BTC,A=886B0F5114C7,P=00
@R,000A,/BTC,0000
@E,001F,BTCON,C=01,A=886B0F5114C7,B=00
@E,000F,PR,C=01,R=0000
@E,000E,ENC,C=01,S=01
@E,0020,BTCF,C=00,A=886B0F5114C7,R=EEEE
@E,001F,BTPDIS,C=00,P=00,H=0003,R=0000
@E,0012,BTDIS,C=01,R=0500
##### QUERY BONDS AGAIN (Now we can see a bond to the right device Address)
/QB
@R,000E,/QB,0000,C=01
@E,0020,B,C=00,A=886B0F5114C7,T=00,D=01
##### CONNECT AGAIN AS PER DATA SHEET (Again error 500?)
@R,000A,/BTC,0000
@E,001F,BTPDIS,C=00,P=00,H=0001,R=0000
##### TRY AGAIN TO CONNECT (Again error 500?)
@R,000A,/BTC,0000
##### TRY AGAIN TO CONNECT (now the error is 1600 and there is nothing in documentation about this error)
@R,000A,/BTC,0000
@E,0012,BTDIS,C=01,R=1600
/QB
PratikshaV
100 solutions authored 5 likes given 250 sign-ins
Hi @carlosfinocchia ,
I hope you are referring this User guide and for error code you can refer page no 239.I will also test this at my end and get back to you soon on this.
Thanks & Regards
Pratiksha V
PratikshaV
Thanks & Regards
Pratiksha V
@PratikshaV Yes that is the same user guide I'm using as reference. Thank you, I have tried pretty much everything in my knowledge and I'm not able to stablish connection.
carlosfinocchia
@PratikshaV Any luck testing this? We really need support on this.
Hi @carlosfinocchia
Sorry for the delayed response..
Please make sure both the devices are disconnected before reconnecting once again. Also please can you share me the detailed logs.
Thanks & Regards
Pratiksha V
carlosfinocchia
@PratikshaV Yes both devices are disconnected before reconnection, What do you mean by "Detailed logs"? What I shared is everything I get on the terminal. (minus the comments i made starting with the "#####")
Please let us know which is your peer device and what are the security features used by this device while connecting.
Thanks & Regards
Pratiksha V
