Since "STM32 Connectivity Expansion Pack 1.1.0" did not have an example of BLE scanning function, I am trying to implement scanning based on "ble_wifi_onbording".
The example I referenced to add the scan is "hello_client".
However, the result of p_scan_result, which stores the scan results, is NULL.
What are the possible causes?
I haven't changed the setting value of wiced_bt_cfg_settings from "ble_wifi_onbording", is that the reason?
<Device used>
・STM32H747I-DISCO
STM32H747I-DISCO STMicroelectronics | Mouser
・LBEE0ZZ1WE-TEMP
LBEE0ZZ1WE-TEMP Murata Electronics | Mouser
・Wi-Fi/BT module: 1DX M.2 Module
1LV M.2 Module - Embedded Artists
It turned out that the cause was mixed paths of different modules in the optional include settings of IAR-EW.
Thank you for your cooporation.
Hi @hi118 :
Which API do you call?
If possible, please your log information or code to me for checking.
Colin
Hi @Qi_Colin
Sorry for my lack of knowledge. what answer do you expect?
Code (app.c)
Functions and callback functions that call wiced_bt_ble_scan() from application_init() which is called after receiving BTM_ENABLED_EVT.
Log(log.txt)
It will be a log from the start until the scan result is found to be NULL.
The last line "Scan completed:" is the log output when the scan result is NULL for him.
hi118
I didn't see anything wrong from your code. Don't know why the scan result is empty.
Could you try the "Bluetooth LE CTS Server" demo which also demonstrates the BLE scan function?
