I have a question about CYBT-343151-02.
https://www.cypress.com/file/457546/download
The temperature range of CYBT-343151-02 is from -30 to +105.
Q1.
Is CYW20706 mounted on CYBT-343151-02 the same device as CYBT-343026-01 (Max temp range: + 85)?
The temperature range of the CYW20706 ranges from -30 to +85.
https://www.cypress.com/file/402156/download
Is the temperature extension version used?
I also checked the following QTP report and found that the High Temp test was up to +85.
https://www.cypress.com/file/454556/download
Q2.
Should I use the Modus Tool Box when developing CYBT-343151-02?
Also, should Target make CYBT-343026-01 an Active set?
TK
I got the information that the part CYW20706UA2KFFB4G can work well in -30 to +105 °C according to the test results from our silicon team. But not sure exactly why it is not updated in the datasheet. I am trying to find out whether there any valid/specific reason for it or not.
-Dheeraj
I hope, all of these modules have same chip. I will confirm this and let you know.
-Dheeraj
-Dheeraj
Thank you for your reply.
I understand that the chip meets the temperature conditions.
How about Q2?
Can I develop software for CYBT-343151-02 with Modus Tool Box?
>Q2.
CYBT-343151-02 module is not supported in Modustoolbox. You can use WICED SDK 6.4 for this module.
CYBT-343026-01 is supported in Modustoolbox IDE and it is active.
-Dheeraj.P.K
