I would like to add a logo to the product using CYBT-343026-01 to indicate that it is compatible with Bluetooth. Will there be an application to put the logo on the product?
Thanks,,
Bluetooth certification is required when selling Bluetooth-enabled products that include the use of the logo under your own brand.
If you use CYBT-343026-01, you will be asked to proceed with the certification process on the web, which does not require testing.
Below is the procedure.
https://www.bluetooth.com/ja-jp/develop-with-bluetooth/qualification-listing/qualification-process-w...
Best Regards
Best Regards
