Hello
We are using the above referenced Eval Board, and will be using the CYW9207 based microprocessor in a design we are working through.
We wanted to know if there were examples or a place where we might find out how to configure the chip to act as BLE Central/Peripheral and if the BLE can bind to more than once device at a single time?
Thank you in advance.
Hi @kmantem ,
Yes we have many code examples available to configure CYW20719B2 as peripheral/central. Please refer Le Hello sensor code example- https://github.com/Infineon/mtb-example-btsdk-ble-hello-sensor
and LE Hello client code example- https://github.com/Infineon/mtb-example-btsdk-ble-hello-client
This BT101 training should also be helpful- https://github.com/Infineon/CypressAcademy_BT101_Files
