Is the CYBT-413055-02 module capable of being A2DP source and handling BLE events at the same time?
I have tested this functionality on the CYW920719B2Q40EVB-01 board, which contains the same MCU (CYW201719B2) as the module. I used the audio watch example for this. However, the CYBT-413055-02 module doesn't have any audio examples. Is there any technical limitation that does not allow it to be used as an A2DP source device? Or should the examples made for CYW920719B2Q40EVB-01 work fine on the module as well?
I'm using the ModusToolbox 2.3.1.
Pista
Wireless
Hi @VIP98 ,
Examples created for CYW20719B2 eval board will work with CYBT-413055-02 module eva board. You will just have to add the support using Library manager for the module.
Hi @VIP98 ,
