3D Hall (Magnetic sensor) Forum Discussions
Sort by:
Vinolzy
in document <Out of Shaft with magnetic 3D sensor>:Out of shaft  "The sensor outputs the magnitude of magnetic field.But the corresponding maximum and... Show More
Ceceliaanne
Hello, everyone,I am working on a product, mainly to detect whether there is a receiver in the finished mobile phone. But because the magnetism of the... Show More
Michael_K
Hello everyone, For one application I want to use 2 TLE493D Hall sensors. Arduino 1.8.15 1. Some time ago I used a XMC 2Go with the TLE493D library v1... Show More
Michael_K
Hello everybody, Hardware: PSoC 4 Pioneer Kit 042 2x TLE493D 3D Hallsensors  The problem is that after I flash or reset the board, the sensors are som... Show More
Rjengr
Hello,   We are using the TLE493D-W2B6 in one of our products, and came across "short-range" mode in the data sheet, however were able to find little ... Show More
Michael_K
Hello everybody, I have some problems to communicate with a 2D hall sensor from Infineon via I2C. First some background information: CY8CKIT-42 PSoC 4... Show More
AsRa_264661
Hi All,Im having the board https://www.infineon.com/cms/en/product/evaluation-boards/tlv493d-a1b6-ms2go/trying to read data from different MCU's.I dow... Show More
User17050
Hi,Is it possible to get the Source code of 3D Magnetic 2Go GUI?I'd need to convert mT to mm at sampled time.thanks in advance,gaston Show More
User21389
Hi, I just connected a "3D Hall 2 Click" module to a 3.3v arduino pro and appear to have i2c communication but all I receive is the value "0"."X = 0.0... Show More
User17520
I am using STM32F303x microcontroller to established the communication with the TLE493D-W2B6 A0. I made the reset commands as said in the manual (Star... Show More
Forum Information
In this forum you can post your questions, comments and feedback about the XENSIX™ 3D Hall sensors, a sensor family (TLx493D) which is using a hall-based technology in order to detect the strength of a magnetic field in all three dimensions, i.e. x-, y- and z-axis. This family fits into industrial and consumer applications such as control elements and joysticks. Furthermore, it is the ideal fit for low-power automotive applications like indicators and gear shifters. Here you can also find the links to the latest board pages, GitHub, documents, simulation tools and FAQs.
