3D Hall (Magnetic sensor) Forum Discussions
Sort by:
rsiigod
Hi everyoneGood day~ I want to develop a linear-type product.Could I get the calibration formula and process used in the GUI?   Furthermore, how do I... Show More
rsiigod
Hi everyoneGood day~When I connect the EVK, then a dialog pops up reminding me to update the firmware.   But the update failed, resulting in an inabi... Show More
User15938
I want to try TLV over I2C with RaspberryPi. I have got the following guide which mentions how to start communication. Just a question that weather sm... Show More
CWHW38759
Hello, I am looking for a magnetic field sensor but not necessarily a position sensor.  I want to be able to sense the magnetic field and sense change... Show More
bem22
Hello everyone,   We're batch testing magnetometers for a new product.   We came across TLE493D-W2B6 and designed PCBs for it. The main issue is... We... Show More
kinetic
Hi, our new product is using a TLV493D. We are using it as a angle sensor at the end of a shaft. We are using a N45 4mmx10mm as per one of your user m... Show More
User15938
I am trying to get values out of my tlv magnetic sensorAll the read registers(00 to 09) gives 0!! I know that sensor enters powr down mode at first so... Show More
Tuxford
Hi All,  I have two the same sensors in my device.  They work properly on one system but only one works properly on three others. Reason the same - no... Show More
User22824
I am having a issue just I wrote in title.I2C address of Tle493d-w2b6 A1 is changing itself(to A0's address)I am working this sensor with Arduino nano... Show More
Vinolzy
in document <Out of Shaft with magnetic 3D sensor>:Out of shaft  "The sensor outputs the magnitude of magnetic field.But the corresponding maximum and... Show More
Forum Information
In this forum you can post your questions, comments and feedback about the XENSIX™ 3D Hall sensors, a sensor family (TLx493D) which is using a hall-based technology in order to detect the strength of a magnetic field in all three dimensions, i.e. x-, y- and z-axis. This family fits into industrial and consumer applications such as control elements and joysticks. Furthermore, it is the ideal fit for low-power automotive applications like indicators and gear shifters. Here you can also find the links to the latest board pages, GitHub, documents, simulation tools and FAQs.
