I have the XMC 2Go kit and the S2GO_3D_TLI493DW2BW-A0 kit. Where is the download to the GUI to use visualize sensor data? No links have worked that were in the documentation and I can't find any working GUI.
Hi @mrask ,
Below is the attached link for the 3D Magnetic Sensor Evaluation Kit.
Link: https://softwaretools.infineon.com/tools/com.ifx.tb.tool.tlx493d
Hope it helps.
Sunil.
Hi @mrask ,
Hope it helps.
Sunil.
Hi Sunil, thank you for the link. After I have that installed and I try to connect to my device, I get "Failed to connect to device" "Device programming failed with unknown error. Please disconnect and reconnect the device"
I've tried both versions of SW available.
Hi @mrask ,
As you created a similar thread, so this query is covered in the following thread link.
Sunil.
