Hi
I want to get the three coordinates values of the magnetic field measured by the sensor of my phone. For this, I get a handle to the SensorManager
by using sm=(SensorManager)getApplicationContext().getSystemService(Context.SENSOR_SERVICE)
, then get the sensor with cm=sm.getDefaultSensor(SensorManager.SENSOR_MAGNETIC_FIELD)
. I then register a SensorEventListener
with sm.registerListener(new SensorListener(),cm,SensorManager.SENSOR_DELAY_UI)
The classSensorListener
is a class of my own implementing the SensorEventListener
interface. In it's OnSensorChanged
method, I get the values from the sensor and I display them. The problem is that I only get the values 1,0 and 0. And they are rarely updated (I have put a counter on the onSensorChanged
calls to see how often the update takes place). Changing the time to SENSOR_DELAY_NORMAL
doesnot improve anything.
To check if the problem was related to the magnetic sensor, I have added, in the same way, a listener to an accelerometer sensor. The result is very confusing : now, the magnetic sensor generates updates, but not the accelerometer one. And if I remove the accelerometer sensor event listener, I still receive the magnetic sensor events which where missing before adding the accelerometer sensor event listener.(???????????)
Any idea about what is wrong in my code?
Hi @VictorJohnsonan ,
The forum is for supporting infineon products only. In case you have any queries on one of our products, we'll be happy to support you.
Deepa
