3D Hall (Magnetic sensor) Forum Discussions
Hello All,
Has anyone programmed TLV493 chip using I2C?
As i am trying to program it with Arduino but I am not able to find the chip address and the regsiter address
Can anyone help me with this.
User270
5 solutions authored First solution authored
See User Manual 3D Magnetic Sensor with I(2) C Interface section 4.2 I2C format description on page 11 ff for Explanation on Default address.
Thank you for your reply
I had seen this before but the Register and the chip address is not precise as different Registers are used to store X,Y and Z direction values.
